rbussolotti
Feb 22, 2021Aspirant
Invalid IP - RBR20
Hi, I was assigned a public IP address from my ISP and when configuring it to my router I keep receiving the Invalid IP message. I checked it and I accurately made all the settings as indicated ...
rbussolotti
Hi,
Thanks for answering.
Yes the settings are as follows:
IP: xxx.yyy.zzz.67
Subnet Mask: 255.255.255.254 (as foreseen in the point/point connections following RFC 3021 specificatiins - https://tools.ietf.org/html/rfc3021)
Gateway: xxx.yyy.zzz.66
DNS Primario: 8.8.8.8
DNS Secondario: 1.1.1.1
Any suggestion?
Thank you
IP: xxx.yyy.zzz.67
Any suggestion?
Thank you
CrimpOn
Feb 22, 2021Guru - Experienced User
I am guessing that this Orbi is past the 90 days of "complimentary support"?
It's ironic that the upper levels of ISP tech support almost certainly have direct links to the major modem and router manufacturers.
Surely Netgear supports an RFC from 20 years ago.
Reading the RFC, my first impression was that the IP's are "backward", i.e. the local host should be 66 and the network end 67.
But, that defies common sense. They provide static IP's all the time.
When does the "Invalid IP" error message come up? Does it provide any information besides "Invalid"?
- rbussolottiFeb 22, 2021Aspirant
Hi,
you're more than right on the 90 days.
No other indication given. The precise message is "192.168.1.1 says Invalid IP" and I get it when I click "Save" after inserting all the parameters.
Thank you
- CrimpOnFeb 22, 2021Guru - Experienced User
Did you try clicking "Test" before clicking "Apply"?
Yes. Same.
