swrtwdrv
Dec 18, 2016Apprentice
Invisible Devices
My iPhone 5c (iOS 10.2) is invisible when connected to a satellite. Satelitte status shows something is connected to 5GHz, but the Connected Devices list is empty. My iPhone does not show up on the Orbi Connected Devices list either. If I move my iPhone near the Orbi router, it shows up on the Orbi Connected Devices list.
- swrtwdrvApprentice
UPDATE
My Orbi router and satellite behave the same way with my wife's iPhone 7 and iPad Mini 4 (both iOS 10.2). Invisible when on the satellite, visible when on the router. The satellite indicates the 5GHz band in use and the 2.4GHz band (No Connection).
UPDATE
My other satellite is exactly the same. Indicates the 5GHz band in use but no connected devices. My two garage door openers on the 2.4GHz band are listed tho.
- bsholbrookApprentice
i've posted a full write up on the satelite and router connection information issues. lots of similar observations.
