gr8sho
Mar 10, 2019Virtuoso
iOS 12.2 beta on iPhone X and connectivity issues with RBR50
Where to begin...
Over the past 24 hours I've seen a rather serious problem with my iPhone X. Symptoms include dropping WiFi Calling, losing wifi connectyity altogther, dropping down to 2.4GHz...
Chuck_M
Mar 10, 2019Mentor
The firmware is out of beta and is now at version .32 for RBR50s.
Update that firmware and see if the issue still exists.
gr8sho
Talking iOS.
I’m already running version 2.3 of orbi firmware. Why do y’all refer to it with suffix instead?
- FURRYe38Mar 11, 2019Guru - Experienced User
There can be many iterations for 2.1, 2.3 and so on. Asking and talking about suffix gives what iteration information which is more important to know about.
- gr8shoMar 11, 2019VirtuosoOkay, thanks.
- ekhalilMar 11, 2019MasterI updated to the iOS 12.2 beta 4 last night when I read your post.
So far everything is working just fine. I can’t see any of the issues you see.
I’m using iPhone 7 Plus.
I just saw that there is now a beta 5 out today. I’m now downloading it.
