dstranathan
Jun 02, 2018Apprentice
iOS devices appear as "Wired"?
Some of my iPhones and iPads (running iOS 11.4) incorrectly appear in the Orbi app and web admin console as "Wired"?
I have my Orbi satellites backhauled via Gigabit Ethernet to my Orbi router ...
budy
Jun 03, 2018Luminary
I have my Orbi satellites backhauled via Gigabit Ethernet to my Orbi router (all rooms were hard-wired with Cat5e runs in my new home at time of construction). But my ihones are not on the physical LAN - they are all using 5G Wi-Fi.
This happens, when you plug the LAN cable where the satellite is connected into the WAN port of the Orbi router. It will work, but the software get's confused, since this plug is only intended for the router, if your Orbi doesn't connect directly to your ISP and operates in AP mode.
Take a look at the manual about wiring satellites for wired backhaul and that issue should go away.
- RocketSquirrelJun 03, 2018Luminary
Nope. My Orbis are all correctly wired and I still see this. My Orbi “router” is in AP mode with its WAN port wired to my Asus router.
- budyJun 04, 2018Luminary
I haven't seen this since 2.1.2.18, when NG seemd to have fixed that issue.
- RocketSquirrelJun 04, 2018Luminary
It comes & goes. At this moment, my 2 i-devices show wireless, and my wife’s 2 i-devices show wired. Pretty random, but the least of my worries.
