johnbday
Dec 19, 2019Tutor
IOS devices cannot configure WiFi log-in of Ecobee thermostats; BAF Haiku fans
After power outage (20 seconds while generator kicks in) 7 Ecobee 3 Lite thermostats and 11 BAF Haiku fans lost WiFi connection to Orbi meshnetwork employing wired backaul to 10G SM Plus Switch. Mac...
- Dec 19, 2019
SOLVED. It appears that an update for the ORBI was released only this morning; while it would not load using the Online Update (automatic) feature, I was able to manually download and install it onto the hub and all satellites. After it installed (had to refresh sceeen to see progress in installation) I ran the ORBI Setup Wizard which slowed to a crawl accessing the Comcast Xfinity wired connection. Immediately afterward I saw virtually all the devices that couldn't reconnect to the network rejoin on their own (one Ecobee couldn't because I had completely disconnected it; after reconnection and re-registration it popped back on too).
So - good news is that the problem is solved. The other news is I can't be really sure if it was today's ORBI firmware update or simply running the Setup Wizard; 'seems pretty clear it had nothing to do with the Switch (settings and firmware for which were not changed).
Thanks to all for your time and patience. Happy Holidays.
Dec 19, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Can try this to see if this helps get the devices reconnected:
johnbday wrote:After power outage (20 seconds while generator kicks in) 7 Ecobee 3 Lite thermostats and 11 BAF Haiku fans lost WiFi connection to Orbi meshnetwork employing wired backaul to 10G SM Plus Switch. Macs and IOS devices all resumed WiFi connectivity. In the past thermos/fans could be rejoined to WiFi network by using IOS Join Network feature in IOS device WiFi settings app. Altneratively WiFi network and password could be manually entered. Neither method now work for both appliances. Fans simply report WiFi conection failure; Ecobees appear to connect to local WiFi network but cannot login externally (to Ecobee.com). Reset Orbi and recreated WiFi network from scratch (using same network name and password); same failures. Ecobee WiFi diagnostics shows no entry in Gateway and DNS fields (which I had thought should have been supplied incidental to log-in to WiFi network).
Any ideas or resources? Since common to two different devices from two different manufacturers whether WiFi log-in is manual or IOS configured, I surmise this is a network problem, although I can't tell if it is the Orbis or the Switch.
johnbday
Dec 19, 2019Tutor
have 3 satellites and 1 RBR 50 base in a two floor large house, but thought that distance wouldn't matter with wired backhaul (it didn't until recently anyway). Forgot to mention checked and updated firmware for both Orbi and Switch. There are actually 2 Ecobees that didn't not lose network connection, and they both show Channel 1 so I have used that in all manual reconnection attempts (using IOS device to configure connection does not offer channel choice, so assume that is Auto). WiFi on Macs/IOS devices shows no networks other than Orbis and th XFINITY network in my cable modem. Armor already disabled. Will try settings adjustments. Assume security setting would make no difference (do not want to operate unencrypted). Thanks!
- FURRYe38Dec 19, 2019Guru - Experienced User
Distance is still a factor even with wired backhaul. You still don't want too much wifi over lap.
johnbday wrote:have 3 satellites and 1 RBR 50 base in a two floor large house, but thought that distance wouldn't matter with wired backhaul (it didn't until recently anyway). Forgot to mention checked and updated firmware for both Orbi and Switch. There are actually 2 Ecobees that didn't not lose network connection, and they both show Channel 1 so I have used that in all manual reconnection attempts (using IOS device to configure connection does not offer channel choice, so assume that is Auto). WiFi on Macs/IOS devices shows no networks other than Orbis and th XFINITY network in my cable modem. Armor already disabled. Will try settings adjustments. Assume security setting would make no difference (do not want to operate unencrypted). Thanks!
- CrimpOnDec 19, 2019Guru - Experienced User
johnbday wrote:Armor already disabled. Will try settings adjustments. Assume security setting would make no difference (do not want to operate unencrypted). Thanks!
There may be some confusion about Armor and security. Key parts of the Orbi system are already encrypted, such as the 5G WiFi backhaul channel (which you are not using). When a user browses to a web site that is "https" that is already encrypted. Orbi already includes a firewall which blocks attempts to connect to Orbi from the internet. What Armor does is "add even more protection", which some users have concluded (a) is unnecessary and (b) interferes with stability and performance. Consider a Windows computer. Windows includes a firewall to protect the computer from attack. Almost everyone uses anti-virus software (either the one Microsoft includes for free or one they choose to install). Some people go farther and add things like MalwareBytes for "more protection." People add "Ad Blockers" to their web browsers.
johnbday wrote:Forgot to mention checked and updated firmware for both Orbi and Switch.
Reading back through the discussion, I do not see the current firmware release on the Orbi.
- johnbdayDec 19, 2019Tutor
- FURRYe38Dec 20, 2019Guru - Experienced User
Thanks for letting us know.
Enjoy. :smileywink:
johnbday wrote:SOLVED. It appears that an update for the ORBI was released only this morning; while it would not load using the Online Update (automatic) feature, I was able to manually download and install it onto the hub and all satellites. After it installed (had to refresh sceeen to see progress in installation) I ran the ORBI Setup Wizard which slowed to a crawl accessing the Comcast Xfinity wired connection. Immediately afterward I saw virtually all the devices that couldn't reconnect to the network rejoin on their own (one Ecobee couldn't because I had completely disconnected it; after reconnection and re-registration it popped back on too).
