johnbday
Dec 19, 2019Tutor
IOS devices cannot configure WiFi log-in of Ecobee thermostats; BAF Haiku fans
After power outage (20 seconds while generator kicks in) 7 Ecobee 3 Lite thermostats and 11 BAF Haiku fans lost WiFi connection to Orbi meshnetwork employing wired backaul to 10G SM Plus Switch. Mac...
- Dec 19, 2019
SOLVED. It appears that an update for the ORBI was released only this morning; while it would not load using the Online Update (automatic) feature, I was able to manually download and install it onto the hub and all satellites. After it installed (had to refresh sceeen to see progress in installation) I ran the ORBI Setup Wizard which slowed to a crawl accessing the Comcast Xfinity wired connection. Immediately afterward I saw virtually all the devices that couldn't reconnect to the network rejoin on their own (one Ecobee couldn't because I had completely disconnected it; after reconnection and re-registration it popped back on too).
So - good news is that the problem is solved. The other news is I can't be really sure if it was today's ORBI firmware update or simply running the Setup Wizard; 'seems pretty clear it had nothing to do with the Switch (settings and firmware for which were not changed).
Thanks to all for your time and patience. Happy Holidays.
johnbday
Dec 19, 2019Tutor
Dec 20, 2019Guru - Experienced User
Thanks for letting us know.
Enjoy. :smileywink:
johnbday wrote:SOLVED. It appears that an update for the ORBI was released only this morning; while it would not load using the Online Update (automatic) feature, I was able to manually download and install it onto the hub and all satellites. After it installed (had to refresh sceeen to see progress in installation) I ran the ORBI Setup Wizard which slowed to a crawl accessing the Comcast Xfinity wired connection. Immediately afterward I saw virtually all the devices that couldn't reconnect to the network rejoin on their own (one Ecobee couldn't because I had completely disconnected it; after reconnection and re-registration it popped back on too).
