esiebert7625's avatar
Jul 12, 2017
IOS disconnects after update
And what a crappy update this is, ironically it says it fixes IOS disconnects which I have never had a problem with. Once this update installed last night I have constant IOS disconnects. Going to downgrade to 1.11.0.20, is there a way to disable auto updates so it doesn't go back on it's own.
1 Reply
  • It looks like that there is no option to disable auto update. Probely you can set up a rule to block the router from accessing the NetGear update server.
