DirkO
Mar 02, 2019Apprentice
iOS not showing satellite
Hi,
Hey team Netgear, and team community you all rock !. for years I wanted wire backhaul on the orbi and "whoe Hoe" its working. So big Thanks !!!.
With very low importance I wanted to s...
- Mar 03, 2019
DirkO wrote:
root@RBR50:/# nvram show | grep satellite[1-9]
-satellite1=A0:04:60:17:11:CC 10.0.10.161 RBS50 4PN1685T03620 -100 V2.3.0.32 0 0 0 0 0
So the printouts and logs show that the router sees the satellite but there is no where that confirms that it's wired. Let's try the following change please, try the following telnet commands:
- config set satellite1="A0:04:60:17:11:CC 10.0.10.161 RBS50 4PN1685T03620 -100 V2.3.0.32 1 A0:04:60:17:13:2A wired 1 -100"
- config commit
After this check the attached devices in the web GUI and the Orbi app.
DirkO
Nope not fixed, Yes i'm running latest version.
Both Router and satellite.
- Firmware Version: V2.3.0.32
ekhalil
Mar 02, 2019Master
What do you see when clicking on Network Map in the app? Is the Satellite missing also there?
- DirkOMar 02, 2019ApprenticeYes satellite is also missing in map see attached pic
- ekhalilMar 02, 2019Master
- What is the version of the IOS app? I have 2.2.13.22
- What happens if you pull down the Network Map to make it force update?
- Have you tried to delete the app and install it again?
- DirkOMar 02, 2019ApprenticeAlso 2.2.13.22
Only thing I didn’t try yet is reinstalling the app.
I did notice that the satellite shows up in the device list
