DirkO
Mar 02, 2019Apprentice
iOS not showing satellite
Hi,
Hey team Netgear, and team community you all rock !. for years I wanted wire backhaul on the orbi and "whoe Hoe" its working. So big Thanks !!!.
With very low importance I wanted to s...
- Mar 03, 2019
DirkO wrote:
root@RBR50:/# nvram show | grep satellite[1-9]
-satellite1=A0:04:60:17:11:CC 10.0.10.161 RBS50 4PN1685T03620 -100 V2.3.0.32 0 0 0 0 0
So the printouts and logs show that the router sees the satellite but there is no where that confirms that it's wired. Let's try the following change please, try the following telnet commands:
- config set satellite1="A0:04:60:17:11:CC 10.0.10.161 RBS50 4PN1685T03620 -100 V2.3.0.32 1 A0:04:60:17:13:2A wired 1 -100"
- config commit
After this check the attached devices in the web GUI and the Orbi app.
maxxvelocity
Mar 26, 2019Aspirant
Same here! IOS Orbi app showing no satellites, but login to router via browser shows both satellites connected. Satellites LED also off, indicating a good connection.
Mar 27, 2019Guru - Experienced User
Make sure the app is up to date. There has been a recent update to the app.
