Flyboy85
Dec 26, 2019Tutor
iOS Updates
Unable to update any Apple product. Apple TV iPhone or iPad will not update to their respective iOS. Keep getting “error downloading” message. I assume it’s some sort of fire wall issue as I can walk ...
Flyboy85
Dec 26, 2019Tutor
Flyboy85
Dec 26, 2019Tutor
Sorry this will be easier
RBR 50 AC3000
Firm:2.3.5.30
RBR 50 AC3000
Firm:2.3.5.30
- FURRYe38Dec 26, 2019Guru - Experienced User
The user manual for this modem suggests it has NAT already built in. This can cuase problems if you install another router which also has NAT built in. Thu giving problems your seeing in this kind of configuration.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Ask them about disabling NAT on the modem:https://www.manualslib.com/manual/1419237/Huawei-Ea380-123.html?page=45#manual
2. If you can't bridge the modem or disable NAT, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- Flyboy85Dec 26, 2019TutorSorry I added an extra A
It’s Huawei- FURRYe38Dec 26, 2019Guru - Experienced User
Let us know how it goes with the modem suggestions.
- Flyboy85Dec 26, 2019TutorThx for the help. Option 1 and 3 didn’t seem to fix it. When we disabled the NAT, i couldn’t get in the internet, unless I did something wrong? 3 didn’t work. I don’t know what IP address to use for 2?
- Flyboy85Dec 26, 2019TutorI just can’t imagine there not being a way to get an iOS update
