builder3303
Sep 06, 2021Aspirant
IoT connection issues
Hi Guys, I'm facing this issue some time ago and I tried almos everything but without any full success. My mesh setup is, one RBR50 2 RBS50 and 1 RBS20 I've in my house 12 switch sonoff conn...
builder3303
Hi,
the sonoff are all T1EU Wifi Smart Switch (1 and 2 gang) with lastest tasmota firmware (the older ones have the same issue)
No, it's not all at the same time, it's 2 or 3 then the others are working good without any issues.
I have the Daisy Chain ON but to test I disable, this is not the solution so I enable it again.
thank you
CrimpOn
Sep 06, 2021Guru - Experienced User
Thanks for the model number. Does this device display an LED pattern when it is off-line, as described in this post:
https://support.itead.cc/support/discussions/topics/11000001238
Sorry my question was not written well. When you notice a switch not working, is the problem limited to certain switches, or is it random?
i.e. one day 2-3 switches may be off-line. Another day 2-3 different switches off-line.
Is there a pattern of failing switches being connected to a specific Orbi unit?
The web interface, Attached Devices page shows which Orbi each switch is connected to.
Is the Ping problem constant and repeatable?
- builder3303Sep 07, 2021Aspirant
- LED pattern
The LED pattern looks like the OFFLINE, if I turn the energy down and up again, sometimes the switch comes on online.
This is what I can see in the switch console.
8:38:05.978 MQT: Connect failed to 192.168.1.11:1883, rc -2. Retry in 120 sec
08:38:33.512 RSL: STATE = {"Time":"2021-09-07T08:38:33","Uptime":"0T18:52:18","UptimeSec":67938,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"MyHome","BSSId":"xxxxxxxxx","Channel":13,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":3,"Downtime":"0T00:00:16"}}
08:40:06.785 MQT: Attempting connection...
08:40:06.996 MQT: Connect failed to 192.168.1.11:1883, rc -2. Retry in 120 sec- switch not working
it's random, example Switch_1 Switch_2 Switch_3 Swtich_4
day one:
Switch_1 on Switch_2 off Switch_3 on Switch_4 offNext days or weeks
Switch_1 off Switch_2 off Switch_3 on Switch_4 on
Next days or weeks
Switch_1 on Switch_2 on Switch_3 on Switch_4 on
next days or weeks
Switch_1 on Switch_2 on Switch_3 off Switch_4 off
I can't get a pattern here... almost the switches are connected to the router, and I have 2 or 3 connected to one satellite installed also on my 0 floor
I can reach the switch web interface if I'm in 0 floor connected to router or the satellite I've here, but I got yo the 3rd floor I can't ping the Switch and i can't reach the web interface
- Ping issue
I've also in 3rd one server with VMs and i can reach all of them, also, when I see one switch offline I make some tests remotely doing router -> 3rd floor and inside the VM 3rd floor -> router
I'm sorry if I'm not explain better way, but this is wired and this only happens with IoT devices specially with switches
Curious fact:
Today I have 2 switches offline, then I unplugged the RBS20 from the energy wait like 5 min and plugged again.
The switches come to online...So, with this test maybe the problem is the communication between the router and satellite loose packages and the switches comes offline somehow...
Another test I will do is, change the RBS20 is on 3rd floor for one RBS50 I've in 0 floor and see if this still happens.
