DrSeuss's avatar
DrSeuss
IP address not assigned
When it works, I really like it.  Unfortunately every 2-7 days it stops communicating with the Xfinity cable modem.  Then nothing.  I've had to d a factory reset every time to get it up and running again.  I spent an hour waiting for Netgear support by phone, but at least had time to do the factory reset and linking the satellites while on hold.  They walked me through a couple of setting tweaks, but it has failed 2 more times since then.   Is there a solution to this?  It seems like several others have had similar issues, but it doesn't seem widespread enough to cause the ratings of the system to be hit hard enough for Netgear to address the issue.  On another note the firmware for my Netgear Readynas pro bricked it too and now I have to find time to mess around with trying to salvage 18Tb of data.  Synology?  Buffalo?  Cisco?  Any other suggestions?  Any decent mesh systems out there?
  • FURRYe38's avatar
    Whats the Mfr and model # of the ISP modem? Built in router here by chance?
    Do you have access to the routers web page and status when this happens?
    What FW version are you using currently on the Orbi?
    Swap out LAN cable between ISP modem and router to be sure. Use good quality Cat6 cable, shortest length possible.
    Do you see any similar problems if you by pass the Orbi and connect a PC directly to the modem?
    • DrSeuss's avatar
      DrSeuss
      Cisco DPC3941T.  I think  that it has a built in router.
      Should I use the Orbi as an access point?
      Access to the Orbi's front page?  Not through the app.  I can try when it fails again through orbilogin.com.  I don't remember if I tried that.
      Yes the FW is up to date.  2.1.4.10. I can't update the app version because it is not "compatible with my device"  Samsung Galaxy Tab S2.
      Cat cable not the issue.  It works great then after a varying amount of time the satellites show the magenta ring, the Orbi no longer has an IP address.and the mesh system is down.  It can work for a week and then locks up.
      Orbi router power down does nothing.  I have to end up with a factory reset and then it works great again, until it doesn't.
      I have connection through the Cisco when the Orbi has locked up.
