rbraitz2's avatar
rbraitz2
IP Address settings not holding
I have my main router at home via FIOS and i have a private IP scheme 192.168.3.1 for the fios router and dhcp starting at 192.168.3.25 for example......the Orbi router has an ip address of 192.168.3.25 and seems to grab the dhcp settings just fine from fios router.  When I try to connect my cell phone, laptop etc. it obtains an ip address of 10.0.0.x .  I can't understand why the orbi router won't give out the ip from the dhcp on the fios router.  and i can't log into my orbi using the ip address that it indicates.  this system is so frustrating to use.  i just want the orbi to be access point and allow whatever connects to it to obtain ip from my fios router not the orbi router, thanks in advance
  • It sounds like your Orbi is still in router mode rather than Acess Point (AP) mode.  Login to the web UI and click on the Advanced tab, then click "Advanced Setup" -> "Router / AP Mode" and click the AP mode button and click Apply.  Once the router reconfigures, it will be in AP mode.
    • rbraitz2's avatar
      rbraitz2
      Thank you very much for your prompt response and it worked!!!
