parisl
Dec 10, 2019Aspirant
IP addresses not being assigned in smart home with many IoT devices
I have a home with 80 Smart "IoT" devices in it. I was running my RBR50 with one satellite for 3 months. Then we had a power outage. Now The devices can't connect. I did a hard reset, and set up the ...
CrimpOn
Dec 10, 2019Guru - Experienced User
One thing to check is on the Orbi web interface, the "Attached Devices" page. Do the devices show up, but are "Blocked"? Does it say that Access Control is "on" or "off"?
- CrimpOnDec 10, 2019Guru - Experienced User
And, when set up this time, is the DHCP range exactly the same as before?
