tandrus89
Dec 02, 2020Guide
IP assignment issue? Devices not connecting
Hi All, Last night I lost power to my orbi, upon restart, only 50% of my devices reconnected. I have ~65 devices between TP Link switches, phones, Alexa devices, and laptops. I thought it was poten...
CrimpOn
Dec 02, 2020Guru - Experienced User
There must be a router somewhere providing IP addresses via DHCP, either (a) the ISP device (if it is a router), or the Orbi. Turniing DHCP off and back on is fine as long as you wind up with one DHCP server somewhere.
Do you have Access Control enabled?
Do many of these devices have IP "assignments" in the LAN Setup table?
tandrus89
Dec 02, 2020Guide
I'm not sure I understand what could be providing DHCP, or how I'd have multiple (novice here -- have just been doing reading on this since experiencing the issues).
Access control is off.
I currently have no address reservations in the LAN setup table.
- FURRYe38Dec 02, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
- tandrus89Dec 02, 2020Guide
How did you know I had a switch hardwired to the router? :)
It's TP-Link 8 Port Gigabit Ethernet Network Switch (TL-SG108)
I use it in this configuration: Modem > Router > Switch > 7 hardwired ports & one smart hub
- FURRYe38Dec 03, 2020Guru - Experienced User
"I have ~65 devices between TP Link switches"
What happens if you remove these switches?
tandrus89 wrote:How did you know I had a switch hardwired to the router? :)
- CrimpOnDec 02, 2020Guru - Experienced User
tandrus89 wrote:I'm not sure I understand what could be providing DHCP, or how I'd have multiple (novice here -- have just been doing reading on this since experiencing the issues).
Sorry for the confusion. I am terribly "literal". That comment, "turned DHCP off/on" threw me. Some users put their Orbi in Access Point (AP) mode and let the ISP router assign IP addresses. You obviously do not. "My Bad"
The WiFi devices that are no longer connecting have been powered off and back on?
Yes - I have gone through the house and reset all smart switches/plugs. Even tried to reset and reinstall them. My phone has been restarted and has the same connection issue mentioned above.
- tandrus89Dec 03, 2020Guide
So I went through a process of elimination -- I went ahead and purchased a new Orbi set thinking it might be a HW issue. It was not -- once connected, it behaved the same and wouldn't connect to all of my devices. I thought possibly it was the router, so I replaced the router as well with an ARRIS, but that's not the issue either. I called Xfinity which indicated through their automated system that my router was offline (despite all lights being on) so they performed a "Reset." Still not working. At a total loss at this point!
