Bloodrule
Mar 17, 2018Tutor
IP cameras connection to Orbi unstable, slow, frequently disconnects
I have six IP cameras that I can connect wirelessly to my Orbi system (reserved IP addresses). However, accessing any or all of the cameras is painfully slow and frequently one or more of the cameras...
- Mar 20, 2018
Happy to report that adding a second satellite appears to have completely solved the problem. All six cameras now working as crisply as ever. Thanks to everyone for contributing to the solution.
Mar 18, 2018Guru - Experienced User
I would disable the following and test with the cameras. Maybe just a couple of cameras at first then add one by one:
Set manual channel 1, 6 or 11 on 2.4Ghz. Any unused channel on 5Ghz.
WPA2 and AES only.
Disable Beamforming, MIMO, Daisy Chain and Fast Roaming. Save settings and reboot both Orbi and Satellite.
waynealight
Mar 18, 2018Apprentice
make sure upnp is enabled, statically assign each camera an ip address and add a port forwarding rule for each camera ip address. just a simple ftp with a complete port range of the cameras. ie 80-8000. this step was not needed before i started using netgear routers but for some reason it does now.
