theClam
Mar 03, 2020Aspirant
IP Passthrough : Orbi RBK53 with ATT Gateway Resulted in Half the Speed
I have my ATT Fiber 1 Gig installed today. With that I begin the IP passthrough setup. ATT Gateway Side: Enabled IP Passthrough Passthrough Mode : DHCPS-Dynamics Turn Off Wireless/WiFi ...
Mar 04, 2020Guru - Experienced User
Yes, your reaching good speeds on wifi and there maxing out. For those devices. I to have a mac book pro with USB C and had to get a LAN to USB C adapter. Mine sees near 900Mpbs on wired for sure.
I would avoid using the speed test app on the RBR. Use Ooklas installable speed test app. Found in the apple store or on there web site for windows.
Probably not. If your getting near 900Mpbs when you can test a wired connection, and your already getting near 400-500Mbps on Wifi, then the Orbi is working as expected...
theClam
Mar 04, 2020Aspirant
Very cool. I guess tonight is the final test! :)
- FURRYe38Mar 04, 2020Guru - Experienced User
Let us know what you find out.
- lhjlmmMar 05, 2020Aspirant
Hi - I recently setup my AT&T fiber BGW210-700 with the Orbi and almost every forum thread I read had the passthrough mode as DHCPS-fixed instead of dynamic. After you select fixed, you choose your RBR50 under the Device List. Not sure if that makes a difference, but just wanted to point that out.
- FURRYe38Mar 05, 2020Guru - Experienced User
Thanks for posting that.
lhjlmm wrote:Hi - I recently setup my AT&T fiber BGW210-700 with the Orbi and almost every forum thread I read had the passthrough mode as DHCPS-fixed instead of dynamic. After you select fixed, you choose your RBR50 under the Device List. Not sure if that makes a difference, but just wanted to point that out.
- theClamMar 05, 2020Aspirant
Direct Connect Test Result Using USB-C and Mac Book Pro 2019.
ATT Arris Modem:
UP: 600
DOWN: 920
Orbi Router:
UP:690
DOWN: 850
Wireless connection are consitently kept at around 400.
All this is without changing any setting. This is my is my original setting.
Looks like Orbi is working as exptected then. Your in the ball park for sure.
