theClam
Mar 03, 2020Aspirant
IP Passthrough : Orbi RBK53 with ATT Gateway Resulted in Half the Speed
I have my ATT Fiber 1 Gig installed today. With that I begin the IP passthrough setup. ATT Gateway Side: Enabled IP Passthrough Passthrough Mode : DHCPS-Dynamics Turn Off Wireless/WiFi ...
lhjlmm
Mar 05, 2020Aspirant
Hi - I recently setup my AT&T fiber BGW210-700 with the Orbi and almost every forum thread I read had the passthrough mode as DHCPS-fixed instead of dynamic. After you select fixed, you choose your RBR50 under the Device List. Not sure if that makes a difference, but just wanted to point that out.
Mar 05, 2020Guru - Experienced User
Thanks for posting that.
lhjlmm wrote:Hi - I recently setup my AT&T fiber BGW210-700 with the Orbi and almost every forum thread I read had the passthrough mode as DHCPS-fixed instead of dynamic. After you select fixed, you choose your RBR50 under the Device List. Not sure if that makes a difference, but just wanted to point that out.
