theClam
Mar 04, 2020Aspirant
IP Passthrough : Orbi RBK53 with ATT Gateway Resulted in Half the Speed
I have my ATT Fiber 1 Gig installed today. With that I begin the IP passthrough setup. ATT Gateway Side: Enabled IP Passthrough Passthrough Mode : DHCPS-Dynamics Turn Off Wireless/WiFi ...
Mar 04, 2020Guru - Experienced User
Let us know what you find out.
theClam
Mar 05, 2020Aspirant
Direct Connect Test Result Using USB-C and Mac Book Pro 2019.
ATT Arris Modem:
UP: 600
DOWN: 920
Orbi Router:
UP:690
DOWN: 850
Wireless connection are consitently kept at around 400.
All this is without changing any setting. This is my is my original setting.
- FURRYe38Mar 05, 2020Guru - Experienced User
Looks like Orbi is working as exptected then. Your in the ball park for sure.
