danielfoster
Jan 08, 2017Guide
iPad 3rd generation slow wifi speeds on Orbi: should I disable WMM / QoS?
Just got Orbi up and running Ookla tests show fast wifi speeds on all of devices except for our 3rd gen IPads Read on Apple Support about disabling WMM / QoS? Would anyone suggest to do that in Orb...
DarrenM
Jan 09, 2017Sr. NETGEAR Moderator
Hello danielfoster
Are you on the latest .34 firmware?
DarrenM
danielfoster
Jan 09, 2017Guide
Thanks, Darren. I just updated to the .34 firmware. Incidentally, how do we know when there's a new firmware upgrade available (besides having to login to orbilogin)? The wifi speed issues are resolved for the 4th gen iPad. But both of our 3rd gen iPads are still capped/throttled at 20 mbps. All other devices are getting over 100 mbps. Any further thoughts? We do have those 2 older blu-ray players attached to our network. Should I remove those from the network or would you suggest I go back in and disable these settings:
Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
Enable MU-MIMO
Thanks again - Dan
