jaydeflix's avatar
jaydeflix
Follower
Oct 23, 2018
iPad frequently disconnecting from Orbi RBR50
So, I'm trying to figure out why a device is consistently dropping its internet connection (in this case, it's an iPad) while staying connected to wifi.
I don't see anything particularly useful on the logging on the Admin page of the orbi. At this point, I'm just looking for suggestions. I'm pondering an OTA packet capture set to only storing ~30min of data and waiting for it to break again.
But I would love to get any other ideas.
1 Reply
  • FURRYe38's avatar
    What FW is currently loaded?
    What is the Mfr and model# of the ethernet switch if one is in the configuration.
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
    https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
    Also try this:
    Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
    https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
    Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
