keeper88
Jun 04, 2017Guide
iPad issues on Orbi
I'm reading a fair amount of issues with iOS devices on Orbi as I'm having issues with iPads intermittently not working. Most times, they show full WiFi signal but can't browse Internet or do speed ...
Retired_Member
Jun 05, 2017Hey Keeper88, when the beta inevitably doesn't work look into the backhaul dropping issue mentioned in some of the other threads. That's your problem.
keeper88
Jun 06, 2017Guide
Thanks Mr. Saget.. I just did a quick read of a couple. When my issues occur, there are other devices successfully connected/working connected to the same rbs40 satellite unit, and I never have drops from non-IOS devices like my PC (wired to a rbs40) and printer (wifi to rbs40). Would that be part of the backhaul issue you're referring to (I would think not, if other devices are working on the same satellite simultaneously)? Or is it a backhaul issue whereby only certain devices may get dropped getting back to the router? Thanks again..
