keeper88
Jun 04, 2017Guide
iPad issues on Orbi
I'm reading a fair amount of issues with iOS devices on Orbi as I'm having issues with iPads intermittently not working. Most times, they show full WiFi signal but can't browse Internet or do speed ...
Retired_Member
Jun 06, 2017The backhaul problem should affect every device connected to the satellite wired or wireless. The drops are quick so a device like a printer would probably show no symptoms. If you try to ping Google with your laptop for a few minutes I bet you will notice some issues.
DarrenM
Jun 07, 2017Sr. NETGEAR Moderator
Hello VMK16
You would have to get a wifi analyzer app Netgear has a free one on the Android store you may have to search for one on the apple store.
DarrenM
- TomMacJun 07, 2017Guru
The app appears on Android store and Kindel store ( android based ) but not on Apple store
