Rusty105
Jul 17, 2019Aspirant
iPad Pro location services not work on Orbi WiFi network
I have Spectrum high speed internet with a Cisco modem connected to Orbi router. All my devices (iPhones, AppleTV, MacBook) connect to the internet and work perfectly except for my iPad Pro. When con...
CrimpOn
Jul 18, 2019Guru - Experienced User
Rusty105 wrote:I have Spectrum high speed internet with a Cisco modem connected to Orbi router. All my devices (iPhones, AppleTV, MacBook) connect to the internet and work perfectly except for my iPad Pro. When connected to my Orbi WiFi network it can not locate the iPad therefore many apps will not work correctly. I have seen several posts of others with same problem but no solutions.
When I Google for "iPad Pro location services", there are numerous results offering suggestions for things to do on the iPad. Since the iPhones, MacBook, etc. are all working, I have a strong suspicion that the solution lies in the iPad rather than in the Orbi.
Rusty105
Jul 18, 2019Aspirant
I’ve googled the same and haven’t found a solution. My location services work everywhere on the iPad except my home orbi network. When away from home on another network it works fine which leads me to believe it is something with my network. I also have an older iPad Pro that does not work at home.
