Rusty105
Jul 18, 2019Aspirant
iPad Pro location services not work on Orbi WiFi network
I have Spectrum high speed internet with a Cisco modem connected to Orbi router. All my devices (iPhones, AppleTV, MacBook) connect to the internet and work perfectly except for my iPad Pro. When con...
Jul 18, 2019Guru - Experienced User
Rusty105
Jul 19, 2019Aspirant
Spectrum technicolor dpc3216 > ng orbi rbr20
additional satellites NG rbs20, rbs50y
- CrimpOnJul 19, 2019Guru - Experienced User
Thanks for the info. The Cisco is definitely "only a modem" (no WiFi, no router functions) so one potential variable is off the table.
I have run across a number of internet comments regarding how "location services" work, specifically on the iPad WiFi only models. Several aviation apps, for example, say definitely, "will not work on a WiFi only iPad because the WiFi iPad does NOT have a GPS, whereas the cellular iPad does a GPS chip."
This is relevant because it seems to be that Apple somehow collects information about where WiFi Access Points are (by MAC address) and gradually builds a master database, and that at times the database does not update very fast. iPhones, of course, have GPS chips in them. Here's a post from three years ago: https://macmost.com/forum/how-do-i-update-my-current-location-in-apples-database.html
- TimtechJul 19, 2019Apprentice
I have had this exact issue.. and did everything on several iPad's in the house to make it work.
If I went to any other WIFI, location would work.. So it was either my ISP or the Orbi. I finally got it working this morning.
I ended up backing up my config file through the Web UI on the Oribi. Then doing a full reset and restore of the config file that I downloaded. Now locations are working on all of my iPad applications. Hopefully that will work for you as well.
- TimtechJul 19, 2019ApprenticeWeird. I see my location updated on all my devices in find my iPhone but hasn’t since restoring my back up config.
Still digging in
