Rusty105
Jul 17, 2019Aspirant
iPad Pro location services not work on Orbi WiFi network
I have Spectrum high speed internet with a Cisco modem connected to Orbi router. All my devices (iPhones, AppleTV, MacBook) connect to the internet and work perfectly except for my iPad Pro. When con...
Rusty105
Jul 18, 2019Aspirant
Spectrum technicolor dpc3216 > ng orbi rbr20
additional satellites NG rbs20, rbs50y
CrimpOn
Jul 18, 2019Guru - Experienced User
Thanks for the info. The Cisco is definitely "only a modem" (no WiFi, no router functions) so one potential variable is off the table.
I have run across a number of internet comments regarding how "location services" work, specifically on the iPad WiFi only models. Several aviation apps, for example, say definitely, "will not work on a WiFi only iPad because the WiFi iPad does NOT have a GPS, whereas the cellular iPad does a GPS chip."
This is relevant because it seems to be that Apple somehow collects information about where WiFi Access Points are (by MAC address) and gradually builds a master database, and that at times the database does not update very fast. iPhones, of course, have GPS chips in them. Here's a post from three years ago: https://macmost.com/forum/how-do-i-update-my-current-location-in-apples-database.html
- TimtechJul 19, 2019Apprentice
I have had this exact issue.. and did everything on several iPad's in the house to make it work.
If I went to any other WIFI, location would work.. So it was either my ISP or the Orbi. I finally got it working this morning.
I ended up backing up my config file through the Web UI on the Oribi. Then doing a full reset and restore of the config file that I downloaded. Now locations are working on all of my iPad applications. Hopefully that will work for you as well.
- TimtechJul 19, 2019ApprenticeWeird. I see my location updated on all my devices in find my iPhone but hasn’t since restoring my back up config.
Still digging in- TimtechJul 19, 2019ApprenticeHmm maps locations still work on the iPads
- Rusty105Jul 19, 2019AspirantI went through Web UI and reset system. Reset it up as an entirely new network. Turned location services off on iPad and turned it off. Turned it back on and joined new network. Restarted location services and still nothing. No timezone or location working. Any other options?
- CrimpOnJul 19, 2019Guru - Experienced User
Is there a forum (similar to this one) for iPad Pro owners? I'll admit it. I am still hung up on, "the iPad has NO GPS chip, so it relies on some Apple database of WiFi MAC addresses for location." How the dickens does the database learn about this Orbi's MAC address?
Obviously, gazillions of iPads work correctly when connected to an Orbi (my wife's does). There has to be a reason.
