Rusty105
Jul 17, 2019Aspirant
iPad Pro location services not work on Orbi WiFi network
I have Spectrum high speed internet with a Cisco modem connected to Orbi router. All my devices (iPhones, AppleTV, MacBook) connect to the internet and work perfectly except for my iPad Pro. When con...
Timtech
Jul 19, 2019Apprentice
I have had this exact issue.. and did everything on several iPad's in the house to make it work.
If I went to any other WIFI, location would work.. So it was either my ISP or the Orbi. I finally got it working this morning.
I ended up backing up my config file through the Web UI on the Oribi. Then doing a full reset and restore of the config file that I downloaded. Now locations are working on all of my iPad applications. Hopefully that will work for you as well.
Rusty105
Jul 19, 2019Aspirant
I went through Web UI and reset system. Reset it up as an entirely new network. Turned location services off on iPad and turned it off. Turned it back on and joined new network. Restarted location services and still nothing. No timezone or location working. Any other options?
- CrimpOnJul 19, 2019Guru - Experienced User
Is there a forum (similar to this one) for iPad Pro owners? I'll admit it. I am still hung up on, "the iPad has NO GPS chip, so it relies on some Apple database of WiFi MAC addresses for location." How the dickens does the database learn about this Orbi's MAC address?
Obviously, gazillions of iPads work correctly when connected to an Orbi (my wife's does). There has to be a reason.
