D18GE
Jun 09, 2019Star
iPad Pro still loosing connection
Following the recommendation to disable Implicit BEAMFORMING in Advanced Wireless/Wireless Settings, I was hoping this would resolve my continuing issue with an 9.7" iPad Pro. See AC3000 RBK50 - iPad Pro WiFi connection issues for previous discussion.
Unfortunately, this has not resolved my connection issues. I have multiple Apple iOS devices using my Orbi and the iPad Pro is the only one that exhibits the problem. Currently on 2.3.1 60 firmware. MU-MIMO and Fast Roaming are also disabled. Everything else is pretty much out of the box setup. Looking for other ideas.
Thanks
Just checking to see if anyone has suggestions.
I'm sorry, I don't have any recommendations, but I see the same thing, and only on my iPad Pro 9.7". Doesn't seem to have happened since I installed the latest iOS 12 beta though?
I'll keep an eye on it and report back.
Stewart
Thanks for the update. What iOS beta are you testing? I am currently on 12.3.1.
