berwickgeek
Oct 19, 2020Aspirant
iPad Pro wifi dropping out on Orbi
I have an Orbi with the Satellite amazon echo. Over the past 6 months or so we've noticed a common behaviour with the iPads and sometimes iPhones in the house. It's a standard 4 bedroom home, sin...
Oct 21, 2020Guru - Experienced User
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
berwickgeek
Oct 21, 2020Aspirant
Thanks - I've going through these settings and will see how it goes.
- FURRYe38Oct 21, 2020Guru - Experienced User
:smileywink:
- Art3000Dec 31, 2020Aspirant
Were you ever able to resolve this issue? I have had the exact same problem with an iPad Pro (while the iPad Airs, iPhones, computers, etc. don't see to have an issue).
- FURRYe38Dec 31, 2020Guru - Experienced User
What iOS is loaded on the iPad? Newer iOS seems to be giving some users problems...
What model Orbi system do you have?
Art3000 wrote:Were you ever able to resolve this issue? I have had the exact same problem with an iPad Pro (while the iPad Airs, iPhones, computers, etc. don't see to have an issue).
RBR50 with one RBS50 satellite. Firmware v2.3.5.30.
Original iPad Pro. Running 14.3.
This is a long standing issue which has presisted through multiple firmware updates and iOS updates. After giving up on fixing it (I can toggle the WiFi to reset the connection), I decided to take another stab.
Note, like the original post, the WiFi only breaks when the iPad is asleep for some period of time. It only happens on the original iPad Pro. A newer iPad pro, multiple iPad Airs, and various iPhones do not show the issue.
Any tips you have are appreciated. Recently, I have turned off fast roaming, beamforming, and the private MAC address (on the iPad) - all items identified as possible tweaks to address similiar issues.
