Beeldbuisje
Mar 14, 2023Guide
iPadOS devices sometimes looses connection with RBR50
Having a strange issue at home and don't know if it's related to my iPad or my RBR50. I own an iPad 8, my wife a 7 and daughter an old Air 2. All three iPads are always at home, connected to ...
- Apr 09, 2023
I indeed switched on the data counter on the RBR. I wasn't aware about the issue around it and it gave me a crazy problem.
I think this topic can be closed. I bought a new iPad Air 2022 and for the time being, this device doesn't gives problems.
In the future I think the old iPad will be used as a central homekit control panel and will be continuously on the charger.
In the mean time, Apple released iPadOS16.4.1. I read somewhere on reddit this could solve some connection issues. Further experiments are necessary.
Beeldbuisje
Apr 04, 2023Guide
Have exactly the same problem with the SXR. Because this mesh set gave no other advantages compared to the RBR50, I sent them back.
Because of the lack of an anti-reflective screen, I already was in the running for a new iPad. But, I want to use the old one as a central controller for my HomeKit setup.
In the mean time, I ordered a new iPad air 2022.
But... I still like to know why the "main" wifi of Netgear gives this issues. I said the "main" wifi, because the guest network gives no problems. The same behavior with the SXR.
Could someone tell me why I should not install the main router of a mesh system into my cellar? Every satellite on the ground and first floor are connected to the RBR by wire.
This device is in use since 2018. The first 3 months, I had several connection issues between RBR and RBS because of the cellar setup. I connect the whole system by wire. Till last December I never had issues (except last Summer when I switched on the data counter. No internet anymore, but I found here this was a bug in the system).
Apr 04, 2023Guru - Experienced User
This sticks out:
"Till last December I never had issues (except last Summer when I switched on the data counter. No internet anymore, but I found here this was a bug in the system)." What do you mean by switched on the data counter? Are you referring to Traffic Meter on the RBR or something on your pad?
- BeeldbuisjeApr 09, 2023Guide
In the mean time, Apple released iPadOS16.4.1. I read somewhere on reddit this could solve some connection issues. Further experiments are necessary. - FURRYe38Apr 10, 2023Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - BeeldbuisjeApr 11, 2023Guide
FURRYe38 wrote:Please mark your thread as solved so others will know.
Thanks for the many clues in this question, but in fact it isn't really solved.
I've never found out why this specific iPad gives problems with Netgear systems.
It's one of those cases we have to say: this is software... not possible to solve this.
- FURRYe38Apr 11, 2023Guru - Experienced User
Plausible faulty problem with the one pad I would presume.
