lowrisk's avatar
lowrisk
Tutor
Apr 10, 2019
IPERF and Orbi RBK53
I'm doing a few iPerf and I'm getting unexpected result.
When I run the iPerf from my router (Synology RT1900AC) / computer I have a normal result (980Mb/s).
When I run an iPerf from my computer (connected on my router) ----- my router connected to the Orbi on WAN1 and my computer connected to the Orbi with Ethernet I only get around 600Mb/s sometime even less (400...)
That's very unexpectred for a local / ethernet result isnt it?
Also I did other iPerf :
Main Orbi to the Satellite, my computer to ethernet via the sat , I get a very bad 300Mb/s (the satelite been 45Feets away in a straight open line).
When I connected to wifi instead, the link that MacOS report or even the Orbi app is 868Mb/s although the Iperf result is between 180 to 260Mb/s
How come my result is so bad? I have a 1Gbit/s internet connection which is a bit pointless at this stage.
1 Reply
  • What Firmware is currently loaded?
    Is the Orbi system operating in Router or AP mode?
    What is your results with with out main host router in the mix?
