RC1972
Sep 15, 2020Aspirant
IPHONE 11 no connection with RBR50 with two satelitte
one of my iphone 11 cannot connect to wifi on RBR50 with two satellite. Please suggest what should i do to make it work. All other devices are working fine. Thanks RC1972
Mstrbig
Sep 15, 2020Master
RC1972 wrote:one of my iphone 11 cannot connect to wifi on RBR50 with two satellite. Please suggest what should i do to make it work.
Thanks
RC1972
The problem is with your iPhone. You need to reset your network settings:
Go to Settings -> General -> Reset and choose Reset Network Settings. You'll have to reconnect to all your Wi-Fi networks and enter their passwords again, so make sure you know the important ones before you begin. Try reconnecting to your wireless router after your iPhone reboots.
- RC1972Sep 15, 2020Aspirant
Still the same issue after resetting Network Settings
The error message "This connection is not private"
Also the same phone is getting connected to other Wifi Network and working fine but not the one in home with Orbi RBR50
