lilspud1
Nov 25, 2019Follower
Iphone 11 speaker won't work when connected to Orbi??
I am running a Orbi RBK50. I upgraded to an iphone 11 and about 75% of the time when my iphone is connected to Orbi and I make/receive a call I can hear the person perfectly clear but they can not he...
Nov 25, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. Fast Roaming, and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Disable Daisy Chain and IPv6.
