Mistylake
Jul 12, 2021Aspirant
iPhone 12 connecting but no signal to RBK50
My iPhone 12 was connected to my Orbi but I cannot get it to connect now. I have updated the router software, phone software, done network reset and shutdown iPhone. My iPad connects perfectly as d...
Jul 12, 2021Guru - Experienced User
What iOS version is on the phone?
Try to "forget this network" option for the SSID name you had it connected to at one time. Then try to reconnect.
Is the RBR using a custom SSID name or the default one?
What security mode do you have set on the RBR? WPA2 and AES only? What happens if you disable WPA security on the RBR temporarily and see if the phone connects? Re-enable WPA2 and AES after testing.
Mistylake
Hi FURRYe38,
thanks for your help.
Firmware V2.7.2.104
IOS 14.6
Custom SSID
Tried disabling WPA2--PSK (AES), still no connectivity.
My phone ticks that's it connected, but there is no signal strength on the top right of my screen.
đ©
