Frustrated21
Dec 13, 2022Follower
Iphone 14 pro max
I just bought a NETGEAR Orbi Tri-band Whole Home Mesh WiFi System with 3Gbps Speed (RBK50) – Router & Extender Replacement Covers Up to 5,000 sq. ft., 2-Pack Includes 1 Router & 1 Satellite White. ...
michaelkenward
Dec 14, 2022Guru - Experienced User
Frustrated21 wrote:
It connects to two mac book pros, two TV's and one I pad. However it will not connect my iPhone 14 pro max. In settings it shows the blue check mark and full bars for internet. But the internet bars are not in the top right hand corner and it says it is not connected to the internet.
Ignore the other answer it takes you to a site that has nothing to do with Netgear. It exists to relieve you of money.
ChristineT and the Netgear team might like to set their lawyers loose.
As to the problem with your iStuff, that really is down to Apple to help you to fix. After all, everything else is working so there doesn't seem to be anything wrong with the router.
You might also find this useful:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
