gbynum
Nov 27, 2019Aspirant
iPhone 7 generating UPnP set event: set & del_nat_rule, DoS Attack: ARP Attack
Orbi RBK22, hot-fix firmware V2.3.5.36 current as of 2019.11.27 Looking at the log, my wife's iPhone (I and others have them too, no issues from them) generates occasional (4-10 times a day) entr...
- Nov 28, 2019
gbynum wrote:.......
The last 4 days, there have been 4 iPhones (2 iPhone 7 which is causing the log entry, same carrier, same firmware) on my network. Only 1 is doing this.
It's an app on your wife's iPhone that's causing the UPnP and the ARP requests, which seem then to be considered as ARP attacks from the phone.
I remember that I also saw the same UPnP messages repeatedly and frequently in the log for my wife's iPhone some time ago! :) and I identified the app at that time, but I don't recall which app it was.
It must be an app that only wives use! ;)
ekhalil
Nov 28, 2019Master
gbynum
Nov 28, 2019Aspirant
So from this, I gather that it is not (likely) a malicious app. Being not malicious, she wouldn't take kindly to my deleting an app for a day to see if it mattered ... only to reinstall anyway since it is not malicious.
OK, at what point should I worry, hundreds or thousands of incidents a day instead of 2-10?
I still would like a non-destructive way to identify it, but I'll mark this solved.
Thanks!
