Kajmon
Apr 15, 2020Aspirant
iphone and all ios devices are not backup since I got Orbi Router
Hi, I got new Orbi RBR50 router & one speaker satellite 3/26. Since then, all my iphone & ipads are not backing up. They all automatically backup to icloud before. I tried 'Maunal back up', Turn on...
Apr 15, 2020Guru - Experienced User
Are you using the same SSID name and PW on the Orbi system from the prior wifi router?
Kajmon
-> No, I changed. I took default name - ORBI39 & make new passowrd.
-> Router Firmware Version V2.5.1.8
->Optimum is my internet provider. Modem is Arris TM1602A .
Thank you very much for help!!!!!
- FURRYe38Apr 15, 2020Guru - Experienced User
Try the prior SSID Name and PW? I would recommend not using the default SSID name. Thats mostly to get the system setup initially and users are encouraged to set a different SSID name.
- KajmonApr 15, 2020Aspirant
I changed SSID Name and PW to my old one to try just now. But it is still not working.
It says 'the last backup could not be completed becasue of poor network conditions'. :(
Any suggestion?
Thank you very much for your help!!
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
