Kajmon
Apr 15, 2020Aspirant
iphone and all ios devices are not backup since I got Orbi Router
Hi, I got new Orbi RBR50 router & one speaker satellite 3/26. Since then, all my iphone & ipads are not backing up. They all automatically backup to icloud before. I tried 'Maunal back up', Turn on...
Kajmon
Are you using the same SSID name and PW on the Orbi system from the prior wifi router?
-> No, I changed. I took default name - ORBI39 & make new passowrd.
-> Router Firmware Version V2.5.1.8
->Optimum is my internet provider. Modem is Arris TM1602A .
Thank you very much for help!!!!!
Apr 15, 2020Guru - Experienced User
Try the prior SSID Name and PW? I would recommend not using the default SSID name. Thats mostly to get the system setup initially and users are encouraged to set a different SSID name.
- KajmonApr 15, 2020Aspirant
I changed SSID Name and PW to my old one to try just now. But it is still not working.
It says 'the last backup could not be completed becasue of poor network conditions'. :(
Any suggestion?
Thank you very much for your help!!
- FURRYe38Apr 15, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).- KajmonApr 15, 2020Aspirant
Hi Furrye38,
I changed all the router set up as you recommended, but still not backup.
I contacted Apple too. They went through all things... They do not know.., and basical told me that they do not know what they can do - since my backup is working in different network (different router), but only not working at Home with Orbi.
Do you think - maybe I got 'Lemon'? Just bad luck?
I really like Orbi... Should I returne it get different one?
I am sorry to bother you so much.
Thank you!
