Don46
Jun 24, 2019Aspirant
iPhone and iPad apps do not recognize Orbi router
I am having a hard time with this. The apps worked earlier, now they will not recognize the router. In fact the wi if connection is working fine. The router and satellite are working together. But ...
Talk2Mike
Jun 24, 2019Apprentice
Possibly a double NAT issue from running a modem in router mode.
Don46
The modem is new and is a Xfinity gigabyte and it does act as a WiFi router. The network has a different name from the Orbi network and I’ve disabled broadcasting the modem network. I can’t see how to disable the modems router function.
What is the solution?
- Talk2MikeJun 24, 2019Apprentice
If you can’t find out how to turn the router into modem mode set the Orbi into access point mode.
- FURRYe38Jun 24, 2019Guru - Experienced User
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
