Craig177
Aug 20, 2018Aspirant
iPhone app not working (vuezone)
I installed the phone app for my Iphone 10 and it won't proceed past a point in loading when it stiops and says Router not found. It wants me to go to settings and activate wifi with Orbi. I have c...
- Aug 21, 2018
Disconnected everything and started from scratch and now everything works. Thanks for the assist.
Aug 20, 2018Guru - Experienced User
What FW is the CBR40 loaded with?
What iOS version are you using on the iPhone?
Might enable remote management on the CBR40, save settings then try the phone app again.
I have mine working on a iphone 6SP iOS 11.4
- Craig177Aug 20, 2018AspirantWhere would I go to enable remote management?
