PJVPHD
Jun 17, 2021Aspirant
iPhone can't find ORBI network
recent issue developed on iPhone (older iPhone 7)... iPhone Orbi app can't find ORBI network ... phone is conected to internet, many apps work with or without cellular turned on... main i...
- Jun 23, 2021Issue was with iPhone…not the Orbi router…phone had a Norton VPN profile loaded which wasn’t used, but interfered with web connectivity… Apple store figured it out and all is working
PJVPHD
Jun 23, 2021Aspirant
Jun 23, 2021Guru - Experienced User
Glad you got it working.
Be sure to mark your thread as solved so others will know. Enjoy. :smileywink:
