mmkeaton's avatar
mmkeaton
iPhone weak signal for wireless calling
My iPhone 7 plus wifi signal is low using my Orbi.  My download speed is 10 Mbps.  My ipads and ipad pros seem to have a strong signal and 29 Mbps.  Phone call are garbled with using wifi calling. My cell signal strength is low and calls on cellular from my house are garbled, so this is a big issue for me.   The main reason I bought the Orbi was to solve this problem!  Not happy spending all this money for nothing unless they can fix it.
I've tried turning off 20/40 Mhz coexistence, disabled MMW, implicit beamforming, mumimo and faster roaming to no avail.
Anyone know how to solve this problem?
RBR50 + SATELLITE
Firmware V2.2.1.210
WPA2-PSK [AES]
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    Find out which Orbi unit the phone is connected too, the base or the satellite.
    Turn off the satellite temporarily while testing the phone with the base router.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
    Enable Beamforming and WMM, save settigs and reboot.
