Skybolt1
Dec 21, 2018Aspirant
Iphone Wont Update APPS
Hello,
I installed this a couple of days ago. Had some problems initially as type my email adress wrong on installation and hence had to ask admin support to update my account with the correct ...
Dec 27, 2018Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
Skybolt1 wrote:
Hello,
I installed this a couple of days ago. Had some problems initially as type my email adress wrong on installation and hence had to ask admin support to update my account with the correct email address. All mostly OK now apart from being unable to configure remote management. I guess they left my incorrect email address in there somewhere!
Anyway my current problem is my Iphone and Ipad (software up to date) cannot download apps or update apps from the apple app store.
It says 'UNABLE TO DOWNLOAD APP, ### app could not be downloaded at this time'.
My PC is fine, I'm using the connection to post this question.
Any ideas of a solution?
ORBI plugged from yellow orbi connection to free wall-mounted router connection. Wall mounted router connected to fibre-optic cable outside.
No problems if I connect my iphone to the built-in wireless network on wall-mounted router.
