Skybolt1
Dec 21, 2018Aspirant
Iphone Wont Update APPS
Hello,
I installed this a couple of days ago. Had some problems initially as type my email adress wrong on installation and hence had to ask admin support to update my account with the correct ...
ekhalil
Dec 27, 2018Master
Skybolt1 wrote:
Hello,
I installed this a couple of days ago. Had some problems initially as type my email adress wrong on installation and hence had to ask admin support to update my account with the correct email address. All mostly OK now apart from being unable to configure remote management. I guess they left my incorrect email address in there somewhere!
Anyway my current problem is my Iphone and Ipad (software up to date) cannot download apps or update apps from the apple app store.
It says 'UNABLE TO DOWNLOAD APP, ### app could not be downloaded at this time'.
My PC is fine, I'm using the connection to post this question.
Any ideas of a solution?
ORBI plugged from yellow orbi connection to free wall-mounted router connection. Wall mounted router connected to fibre-optic cable outside.
No problems if I connect my iphone to the built-in wireless network on wall-mounted router.
This issue was reported many times in this forum. The problem is usually caused by having 2 routers in your network.
Please make sure to bridge your "wall-mounted" router so it will not act as a router or if you can't do that then you need to set Orbi in AP mode (I guess that you currently have it in the default Router Mode).
