mruport
May 08, 2023Aspirant
IPTV Being Blocked
I actually have THe Orbi Router RBR20. It is connected to my ISP (local Coop). I also have the ONN android tv box and have been using it with the A1IPTV (nocable.cc) service for 6 months or so. I hav...
May 08, 2023Guru - Experienced User
Have made sure the vlan's are set for your service?
- mruportMay 12, 2023Aspirant
Sorry so late getting back to you. My system is actually an Orbi Router RBR20. My app does not have those same settings. It is the router that is my problem. I used my phone as a hotspot using just cellular data and connected my Onn Android TV box to it and my IPTV works. If I connect my Onn box to my house wifi it doesn't work. I do not see anything in the logs, parental controls are off. I can't figure this out
- plemansMay 13, 2023Guru - Experienced User
You set the vlans in the router.
did you read the article ?
I have the Orbi RBR20 and it has been working fine for a year or so. The other day my IPTV stopped working. I used my phone as a hotspot (using just cellular service) and connected my Onn Android TV box to it and the IPTV works (but is slow). If I switch back to my Orbi router, the IPTV does not work. Everything else works on the Onn box (YouTube, Netflix etc). I don't see anything in the log file that says anything is being blocked. I even factory reset my Orbi and that didn't help either. Using the command prompt I can ping the IPTV server (www.nocable.cc). Parental controls are off and my Netgear Armor is expired so that is off. Any help would be appreciated. Thank you
