mruport
May 08, 2023Aspirant
IPTV Being Blocked
I actually have THe Orbi Router RBR20. It is connected to my ISP (local Coop). I also have the ONN android tv box and have been using it with the A1IPTV (nocable.cc) service for 6 months or so. I hav...
mruport
May 12, 2023Aspirant
I have the Orbi RBR20 and it has been working fine for a year or so. The other day my IPTV stopped working. I used my phone as a hotspot (using just cellular service) and connected my Onn Android TV box to it and the IPTV works (but is slow). If I switch back to my Orbi router, the IPTV does not work. Everything else works on the Onn box (YouTube, Netflix etc). I don't see anything in the log file that says anything is being blocked. I even factory reset my Orbi and that didn't help either. Using the command prompt I can ping the IPTV server (www.nocable.cc). Parental controls are off and my Netgear Armor is expired so that is off. Any help would be appreciated. Thank you
May 13, 2023Guru - Experienced User
What modem/gateway is the orbi connected to?
Does your isp need vlan's set for their iptv services?
