mruport
May 08, 2023Aspirant
IPTV Being Blocked
I actually have THe Orbi Router RBR20. It is connected to my ISP (local Coop). I also have the ONN android tv box and have been using it with the A1IPTV (nocable.cc) service for 6 months or so. I hav...
May 13, 2023Guru - Experienced User
You set the vlans in the router.
did you read the article ?
mruport
May 13, 2023Aspirant
One other thing. I am not getting my IPTV from my ISP so do I not need to do what the article said?
- schumakuMay 14, 2023Guru - Experienced User
....so very unlikely you resp. this A1xIPTV are using an IGMP Multicast based transport coming over a VLAN direct from your internet ISP. So the answer is yes, you don't have to take care about the article referred.
To round this up, your computer or App installed on whatever IPTV-box does very likely use singlecast.
