mruport
May 08, 2023Aspirant
IPTV Being Blocked
I actually have THe Orbi Router RBR20. It is connected to my ISP (local Coop). I also have the ONN android tv box and have been using it with the A1IPTV (nocable.cc) service for 6 months or so. I hav...
schumaku
May 14, 2023Guru - Experienced User
Still confusing.
What you designate as IPTV - in my reading this fancy A1+IPTV app (correct?) - is probably yet another application like for example YouTube - as such it's technically unrelated to the dedicated VLAN based ICMP Muticast (live) TV.
Or are you using an IPTV Box by (or for) implemented by your ISP, like Calix does for hundreds of IPTV providers, like your small Coop mentioned, and using an IPTV VLAN as designated by your ISP?
The same applies when using a mobile hotspot. Unlikely there is ICMP based Multicast involved. Even on advanced 5G networks here, we don't have any Multicast based IPTV. All live and VOD is coming in by UDP Unicast over the carrier mobile network.
mruport
May 14, 2023Aspirant
I'm sorry but I don't know what any of that means. I did go buy a new Netgear NightHawk router and my IPTV works now.
