larryktlee
Feb 26, 2017Initiate
IPv6 DHCP-PD Issue in Orbi
The problem is as follows:
My ISP is to support native IPv6 (SLAAC) for WAN + DHCP-PD for LAN. I cannot connect the IPv6 through my iPHONE every reboot.
After 1 days, I cannot connect IPv6 site again. From iPhone, there is no IPv6 address obtained. It seems that the DHCP-PD is timeout without renewal.
If I tried to reboot the Orbi again, the IPv6 can be used with new prefix. The same situation haven't been found when I used ASUS-87U previously.
So that I think the problem may be in ISP.
- DarrenMSr. NETGEAR Moderator
Hello Larryktlee
have you checked with the ISP on this yet?
DarrenM
- larryktleeInitiate
Yes, the problem is not from ISP. It is because I tried to use netgear R7000 and netgear 6300v2. There is no DHCP-PD timeout issue.
