futelihut
Apr 04, 2019Aspirant
IPv6 DHCPv6 Prefix Delegation
Hi
My ISP requires Prefix Delegation for IPv6 support.
Is there a way to configure the RBK50 router to fetch prefix delegation from my ISP?
Or is it not supported?
/Morten
Apr 04, 2019Guru - Experienced User
I believe under Advance Settings there is IPv6 menu and a drop down menu. Select from the menu of IPv6 options. ISP should be able to tell you which one to use.
Review the user manual starting at page 39:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
